Property Name | Sample Value | Description |
os.namespace | The Object Storage namespace serves as a container for all your buckets and objects. Define the namespace where the buckets and objects the GL extract file resides. This is used when calling the Object Storage APIs. Shared property for all flows in this integration. | |
os.gl.bucketname | Bucket Name to where the objects or files are stored. Define the bucket name where the GL Extract file is stored. This is used when calling the Object Storage APIs. | |
gl.extract.filename.prefix | GL Extract file name prefix This should have the same value as the batch parameter filename in Batch Process C1-GLFCX. | |
os.apreq.bucketname | Bucket Name to where the objects or files are stored. Define the bucket name where the AP Req Extract file is stored. This is used when calling the Object Storage APIs. | |
apreq.extract.filename.prefix | The AP Req Extract file name prefix. This should have the same value as the batch parameter filename in Batch Process C1-APFCX. | |
prefixtag.fileuploaded | Uploaded | The text to append to the Ap Req Extract filename to mark the file as processed or uploaded in Object Storage or FTP. Shared property for all flows in this integration. |
apreq.input.directory | Folder path in which AP Request file is generated for CCB on-prem scenario from which OIC picks and process file to EBS. | |
gl.ftp.input.directory | Folder path in which GL Extract file is generated for CCB on-prem scenario, OIC picks and process file to EBS from this location | |
ftp.download.directory | Stage directory in OIC to process the files downloaded from CCB server folder | |
prefixtag.fileerrored | The text to append to the Ap Req Extract filename having the processing errors. | |
invoice.line.description | Default invoice line description when there is no value sent from CCS in the Ap Req Extract. | |
ap.ftp.fileuploaded. directory | FTP directory where the uploaded Ap Req Extract file will be move after being successfully processed. | |
gl.ftp.fileuploaded. directory | FTP directory where the uploaded GL Extract file will be move after being successfully processed. | |
ap.os.fileuploaded. directory | Object Storage directory where the uploaded Ap Req Extract file will be move after being successfully processed. | |
gl.os.fileuploaded.directory | Object Storage directory where the uploaded GL Extract file will be move after being successfully processed. | |
ap.ftp.fileerrored.director | FTP directory where the errored Ap Req Extract file will be created. | |
gl.ftp.fileerrored.directory | FTP directory where the errored GL Extract file will be created. | |
ap.os.fileerrored.directory | Object Storage directory where the errored Ap Req Extract file will be created. | |
gl.os.fileerrored.directory | Object Storage directory where the errored GL Extract file will be created. |
