Solution Overview
The technical aspects involved in Oracle Utilities Customer Cloud Service Integration to Oracle E-Business Suite for General Ledger and Accounts Payable are:
• The integration layer is made up of integration processes deployed on Oracle Integration Cloud.
• The integration processes uses Oracle EBS Adapter to integrate with Oracle E-Business Suite (EBS) applications:
• Some processes uses the open interface API, such as Journal Import and Payables Import.
• Some processes uses custom APIs to create or update vendors and vendor sites also to extract Payment Request data.
• It uses REST APIs to communicate with Object Storage and Oracle Utilities Customer Cloud Service application.
• The FTP Adapter is used to perform all file operations in the FTP/SFTP server.
• The integration pattern used for the solution is:
• Scheduled integration for all flows.
Refer to the Business Flows section for more information on each integration process.
