Configuring Lookups
The following table lists the lookups that are part of this integration.
The lookups are only used for Account Payable Data Sync (Oracle ERP Financial AP initiated).
DVM Name
Description
CCSERPFIN_Currency
Map Currency Code between Oracle Customer Cloud and Oracle Financial Cloud
CCSERPFIN_PaymentMethod
Map Payment Method between Oracle Customer Cloud and Oracle Financial Cloud
The following lookups are part of all three integration flows:
DVM Name
Description
CCSERPFIN_ConfigProps
Shared by all flows in this integration.
Maps PropertyName column to the respective Value Column. Do not change the values in PropertyName column.
CCSERPFIN_Email_Id.dvm
Maps from and to recipient values to the mentioned email IDs.User can configure multiple emails by putting comma to separate the email IDs.
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Integrations > Designer > Lookups.
3. Select the look up to edit.
4. Make the necessary changes.
5. Click Save and Close.
