Configuring Lookups
The following table lists the lookups that are part of this integration.
Lookup Name
Integration Name
Purpose
OUTL-BRT-DACS_OFSC_
AttachmentBO
OU OFSC DACS Activity Complete
Translates OFSC attachment MIME type to DACS BO name.
Note: Only on the edit of a service history, can we add an attachment to a service history. If a specific file type cannot be attached at service history, check if the corresponding file type is mentioned in this lookup; add it if is missing. Also, verify if the respective MIME type is available in OFSC properties dacs_upload_attachment_1 to dacs_upload_attachment_5.
OUTL-BRT-DACS_OFSC_ActivityLinkType
OU DACS OFSC Activity Process
Translates the DACS Activity Link Type to OFSC Activity Link Type.
Note: Configure the OFSC second activity link label.
OUTL-BRT-DACS_OFSC_ActivityType
• OU DACS OFSC Activity Process
• OU OFSC DACS Activity Pull Update
Translates the DACS Activity Type to OFSC Activity Type.
OUTL-BRT-DACS_OFSC_Email_ID
• OU OFSC DACS Activity Interim Status
• OU OFSC DACS Resource Usage Details
• OU OFSC DACS Work Order
• OU OFSC DACS Activity Complete
• OU DACS OFSC Admin Data Sync
• OU OFSC DACS Work Request
• OU OFSC DACS Asset Query
• OU OFSC DACS Route Activation
• OU DACS OFSC Schedule Storeroom Sync
• OU OFSC DACS Storeroom Sync
• OU DACS OFSC Storeroom Admin Sync
Used to configure the email IDs of the respective users.
Under the Email_Id column where the Recipient value is “to”, add comma separated email IDs to send an email to multiple users.
Do not change or add any values under the Recipient column.
OUTL-BRT-DACS_OFSC_
ConfigProps
Used for configurable properties.
OUTL-BRT-DACS_OFSC_Language
Translates the language code from DACS to OFSC.
OUTL-BRT-DACS_OFSC_
ActivityStatus
Translation between the DACS Activity status and the OFSC status.
OUTL-BRT-DACS_OFSC_
SegmentedActivityTypes
Used to identify activity types in OFSC that needs segmentation.
OUTL-BRT-DACS_OFSC_ActivityTypeConfigProps
Used to synchronize between the two systems
OUTL-BRT-DACS_OFSC_
ServiceArea
Maps service area to the bucket name
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Integrations > Lookups.
3. Select the lookup to edit.
4. Make the necessary changes.
5. Click Save and Close.
