Supported Applications and Versions
The following table lists the supported application versions in this integration:
Version
Oracle Utilities Digital Asset Cloud Service
23B or higher
Oracle Integration Cloud
V23.12 or higher
Oracle Field Service
23D or higher
This site works best with JavaScript enabled
