Table Name: ces_parameters | Insert or update the value with OIC flow end point url for Orders as <https://hostname:port/ic/api/integration/v1/flows/oracleutilities/OUTL-BA-NMS_OFSC_ORDERS/1.0/orders> where the app like MWM%' and attrib='mwm.url.CreateUpdateOrder' |
Insert or update the value with OIC flow end point url for Orders Completed as <https://hostname:port /ic/api/integration/v1/flows/oracleutilities/OUTL-BA-NMS_OFSC_ORDERS_COMPLETE/1.0/orders/complete> where the app like ‘MWM%' and attrib='mwm.url.CompleteOrder’ | |
Insert or update the value with OIC flow end point url <https://hostname:port/ic/api/integration/v1/ flows/oracleutilities/OUTL-BA-NMS_OFSC_PING 1.0/ping> where the app like MWM%' and attrib='mwm.url .PingURL' | |
Insert or update the value with <oic username> where the app like 'MWM%' and attrib=' mwm.username' | |
Insert or update the value with <oic password> where the app like 'MWM%' and attrib=' mwm.password' | |
Insert or update the value as <false> where the app like 'MWM%' and attrib=' config.suppress_ws_errors' | |
Insert or update the value with <oic oauth token url> where the app like 'MWM%' and attrib='config.auth.token.url' | |
Insert or update the value with < oic oauth token scope> where the app like 'MWM%' and attrib='config.auth.token.scope' | |
Insert or update the value with <oic oauth token user> where the app like 'MWM%' and attrib= 'config.auth.token.user' | |
Insert or update the value with <oic oauth token password> where the app like 'MWM%' and attrib= 'config.auth.token.pwd' |
Table Name: ces_parameters | Insert or update the value with '<max number of call to send from NMS>'where the app like 'MWM%' and attrib=' config.call_send_limit' |
