Extension Libraries in Oracle Integration Cloud
The extension libraries provide a means to register and organize JavaScript for use in integrations. Library functions are automatically available for you to drag from the Actions palette to your orchestration integrations.
This integration includes the following extension libraries:
Extension Library
Function
Description
Used in Integration Process
WAMOFSC_AddOffsetTo
DateTime
WAMOFSC_addOffsetTo
DateTime
Adds the offset needed for conversion
Oracle Utilities OFSC WACS Activity Complete
WAMOFSC_ConcatAddress
Concatenates the address information
Oracle Utilities WACS OFSC Activity Process
The same extension libraries can be accessed from the Libraries page in Oracle Integration Cloud. For more information about extension libraries, refer to the Oracle Integration Cloud documentation at: https://docs.oracle.com/en/cloud/paas/integration-cloud-service/index.html
