Inventory Types
The inventory types (such as asset, material, and so on) are stored in Oracle Field Service.
To add an inventory type:
1. Navigate to Configuration > Resources, Activities, Inventories > Inventory Types.
2. Click Add New.
3. Enter the details as shown below and click
Save.
![Asset inventory type window. The user is to write Asset on the Label text field, check Active checkbox, write Assets on English name field, and write FR Assets on the French name field. Save button is located on the bottom right corner. Asset inventory type window. The user is to write Asset on the Label text field, check Active checkbox, write Assets on English name field, and write FR Assets on the French name field. Save button is located on the bottom right corner.](../WACS-OFS-SETUP-GUIDE/images/additionalOFS-inventorytypes-details-img24.png)
![Material inventory type window. The user is to write Material on the Label text field, check the Active and Non Serialized checkboxes, write Materia on the English name field, and write quantity on the English text field on the Unit of Measurement section. Save button is located on the bottom right corner. Material inventory type window. The user is to write Material on the Label text field, check the Active and Non Serialized checkboxes, write Materia on the English name field, and write quantity on the English text field on the Unit of Measurement section. Save button is located on the bottom right corner.](../WACS-OFS-SETUP-GUIDE/images/additionalOFS-inventorytypes-materialdetails-img25.png)
![Equipment inventory type window. The user is to write Equipment on the Label text field, check the Active and Non Serialized checkboxes, write Equipment on the English name field, and write Each on the English text field on the Unit of Measurement section. Save button is located on the bottom right corner. Equipment inventory type window. The user is to write Equipment on the Label text field, check the Active and Non Serialized checkboxes, write Equipment on the English name field, and write Each on the English text field on the Unit of Measurement section. Save button is located on the bottom right corner.](../WACS-OFS-SETUP-GUIDE/images/additionalOFS-inventorytypes-equipmentdetails26.png)
4. Repeat step 2 for StockItem, StockAsset, issuedAsset, and issuedComponent.
![StockAsset inventory type window. The user is to write StockAsset on the Label text field, check the Active and Non Serialized checkboxes, write Assets on the English name field, and write asset on the English text field on the Unit of Measurement section. Save button is located on the bottom right corner. StockAsset inventory type window. The user is to write StockAsset on the Label text field, check the Active and Non Serialized checkboxes, write Assets on the English name field, and write asset on the English text field on the Unit of Measurement section. Save button is located on the bottom right corner.](../WACS-OFS-SETUP-GUIDE/images/additionalOFS-inventorytypes-stockassetdetails28.png)
Note: Default Quantity precision is set to 2. The user can configure it according to the requirement.
![IssuedAsset inventory type window. The user is to write issuedAsset on the Label text field, check the Active checkbox, and write Issued Assets on the English name field. Save button is located on the bottom right corner. IssuedAsset inventory type window. The user is to write issuedAsset on the Label text field, check the Active checkbox, and write Issued Assets on the English name field. Save button is located on the bottom right corner.](../WACS-OFS-SETUP-GUIDE/images/additionalOFS-inventorytypes-issuedassetdetails29.png)
![IssuedComponent inventory type window. The user is to write issuedComponent on the Label text field, check the Active checkbox, and write Issued Components on the English name field. Save button is located on the bottom right corner. IssuedComponent inventory type window. The user is to write issuedComponent on the Label text field, check the Active checkbox, and write Issued Components on the English name field. Save button is located on the bottom right corner.](../WACS-OFS-SETUP-GUIDE/images/additionalOFS-inventorytypes-issuedcomponentdtls31.png)
