Configuring Lookups
The following table lists the lookups that are part of this integration.
Lookup Name
Integration Name
Purpose
OUTL-BRT-ArcGIS_OFS_ConfigProps
• OU ArcGIS OFS Work Task Process
• OU ArcGIS OFS Admin Files Create
Used for configurable properties.
OUTL-BRT-ArcGIS_OFS_Email_ID
Used to configure email IDs of the respective users.
Under the Email_Id column where the value of Recipient is “to”, add comma separated email IDs to send an email to multiple users.
Do not change or add any values under the Recipient column.
OUTL-BRT-ArcGIS_OFS_ActivityType
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Integrations > Lookups.
3. Select the look up to edit.
4. Make the necessary changes.
5. Click Save and Close.
