Property Name | Sample Value | Description | Used in Integration Process Name |
source.system | WACS | Defines the WAM or WACS product code | OU ArcGIS OFS Admin Files Create |
notification.email.error. flag | true | If the value is set to ‘true’, email notification will be sent out for errors. Valid values: true/false Default: true Also, setup the OUTL-BRT-ArcGIS_OFS_Email_ID 'to' property for the users or administrators who should receive the email. | OU ArcGIS OFS Admin Files Create |
notification.email.process.complete.flag | true | Configures the optional email notification. If the value is set to ‘true’, email notification will be sent to the configured users. Also, setup the OUTL-BRT-ArcGIS_OFS_Email_ID 'to.process.notification' property for the users or administrators who should receive the email. | OU ArcGIS OFS Admin Files Create |
asset.inventory.type | Asset | OU ArcGIS OFS Work Task Process | |
ofsc.bucket | OHMeter | Configure the default bucket to assign the activities. | OU ArcGIS OFS Work Task Process |
from | arcgis-ofs@email.com | Defines the WAM or WACS product code | OU ArcGIS OFS Admin Files Create |
to | errorDist@myCy.com | The email address(es) who should receive any error notification. Multiple emails can be configured by putting comma to separate the email IDs. These are likely the administrators or users who maintain the applications. | OU ArcGIS OFS Admin Files Create |
to.process.notification | busUserDist@myCy.com | The email address(es) who should receive notification when the processing has completed. Multiple emails can be configured by putting comma to separate the email IDs. These are likely the business or application users. | OU ArcGIS OFS Admin Files Create |
