Verifying the Project Import
To verify the project import was successful:
1. Verify whether the following integrations are imported successfully as seen in the Integrations section of the project:
• OU ArcGIS OFS Work Tasks Process
• OU ArcGIS OFS Admin Files Create
2. Verify whether the following connections are imported successfully as seen in the Connections section of the project:
• OU REST ArcGIS for ArcGIS-OFS
• OU SOAP WACS for ArcGIS-OFS
• OU REST ArcGIS OS for ArcGIS-OFS
• OU REST OFS API for ArcGIS-OFS
• OU REST OFS for ArcGIS-OFS
3. Make sure that the following lookups are imported successfully as seen in the Lookups section of the project:
• OUTL-BRT-ArcGIS_OFS_ConfigProps
• OUTL-BRT-ArcGIS_OFS_Email_ID
• OUTL-BRT-ArcGIS_OFS_ActivityType
