Supported Applications
The following applications are required/supported in the integration:
• Oracle Utilities Work and Asset Management
Note that the on-premises versions (Oracle Utilities Work and Asset Management) may have limited functionality as they trail cloud-based versions (Oracle Utilities Work and Asset Cloud Service) due to the release frequency.
• Oracle Utilities Work and Asset Cloud Service
• Oracle Integration Cloud
• Oracle Field Service
• ESRI ArcGIS Field Maps
For specific application versions, refer to the
ESRI ArcGIS Field Maps Integration to Oracle Field Service Mobile Release Notes included in this release. The documentation is available on Oracle Help Center at:
https://docs.oracle.com/en/industries/utilities/integrations-index.html
