Creating Database Connection in ArcGIS Pro
As part of the integration, the Tasks Workspace document is provided as the ArcGIS artifact. This xml file defines the schema of the Tasks feature class. The workspace document will be imported into a geodatabase.
To create a Oracle database connection in ArcGIS Pro for Enterprise geodatabase:
1. Click New Database Connection.
2. Enter the connection details, such as Oracle instance, username, and password.
3. Click Validate and then click OK to verify the connection is successfully created.
Note that the Oracle database connection requires Oracle database client software to be installed on the machine running ArcGIS Pro. For more information about connecting to Oracle database from ArcGIS Pro, refer to: https://pro.arcgis.com/en/pro-app/latest/help/data/databases/connect-oracle.htm
