Updating Contingent Values
The “FieldGroup” and “ContingentValues” CSV files are generated using the “OU ArcGIS OFS Admin Files Create” Oracle Integration Cloud workflow. These files are stored in the OCI Object Storage in the configured buckets. After the files are downloaded from the buckets, they can be imported into the Tasks feature class using ArcGIS Pro.
To load the Tasks feature class:
1. Right-click the Tasks feature class in the geodatabase and then click Open Table.
2. Click
Fields to view the options related to
Table Fields.
3. Click
Contingent Values to view the options related to contingent values.
4. Click
Import.
5. Select the FieldGroup and ContingentValue files. Make sure the Replace Values field is selected.
6. Save the changes.
