Publishing Feature Class on ArcGIS Online
To publish the Tasks feature class either on ArcGIS Online or on ArcGIS Enterpriser Server:
1. Navigate to Share > Web Layer > Publish Web Layer.
2. Enter the necessary information and configuration, analyze and then publish the feature layer.
OAuth Security
The Tasks feature layer on ArcGIS Online can be accessed using OAuth 2 Client Credentials in the “OU REST ArcGIS for ArcGIS-OFS” Oracle Integration Cloud connection for the “OU ArcGIS OFS Work Tasks Process” integration work flow.
To create an OAuth2 application:
1. Login to ArcGIS Online.
2. Create a New Item of type Developer Credentials.
3. Navigate to Settings to fetch the ClientId and Client secret of the application to use in the Oracle Integration Cloud connection.
