Field Name | Description | Data Type | Domain Values | Visibility in Work Order /Work Request |
OBJECTID | Object Id | Object ID | ||
WORK_TYPE | WAM Work Types | Text | Tasks_WorkType | |
ACTIVITY_TYPE | WAM Activity Types | Text | Tasks_ActivityType | |
WORK_PRIORITY | WAM Priority Types | Text | Tasks_WorkPriority | |
WORK_CLASS | WAM Work Class | Text | Tasks_WorkClass | |
WORK_CATEGORY | WAM Work Category | Text | Tasks_WorkCategory | |
GROUP_TYPE | WAM Group Type | Text | Tasks_GroupType | |
TASK_TYPE | Form type to enter. Possible values are ‘Work Order’ or ‘Work Request’. Corresponding values are visible or hidden based on the value selected. Default value: Work Request | Text | Tasks_Type | Work Order/Work Request |
GISID | Global ID of the asset for which work order or work request is created. | Text | ||
REQUIRED_BY_ DATE | Required by date of work order or work request | Date | ||
DETAILED_DESC | Detailed description | Text | ||
DESCRIPTION | Description | Text | ||
WORK_IT | Indicates if the work order is assigned to the fieldworker creating it. | Text | Tasks_YesNo | Work Order |
EMERGENCY | If it is an emergency task | Text | Tasks_YesNo | Work Order |
DOWNTIME_START_DTTM | Downtime start date and time | Date | ||
CREW_MEMBER | Enterprise portal user ID of the user submitting the tasks form | Text | ||
EXTERNAL_REC_ INFO | This field holds the OFS Activity ID for work order or OFS service request number for work request. Default value: N | |||
GLOBALID | Global ID of Tasks record | Global ID | ||
CREATOR | Editor tracking field. Stores the username of the who created the feature record. | Text | ||
CREATIONDATE | Editor tracking field. Creation date of the feature record. | Date | ||
EDITOR | Editor tracking field. Stores the username of the who edited the feature record. | Text | ||
EDITDATE | Editor tracking field. Edit date of the feature record. | Date | ||
SHAPE | Geometry of the feature, which is a point. | Geometry |
Domain Value Name | Sample Values | Updated by csv files |
Tasks_WorkType | Code: W1PM Description: Preventive Maintenance | Yes |
Tasks_ActivityType | Code: WD-LeakRepair Description: Activity - Gas Leak Repair | Yes |
Tasks_WorkPriority | Code: 01 Description: 01 | Yes |
Tasks_WorkClass | Code: WDPL Description: Planned | Yes |
Tasks_WorkCategory | Code: WDFL Description: Failure | Yes |
Tasks_GroupType | Code: WACS Description: WACS | No |
Tasks_Type | Code: WR Description: Work Request | No |
Tasks_YesNo | Code: N Description: No | No |
