Regenerating CSV Files
If the admin data associated with various dropdowns on work order and work request needs to be updated, run the the “OU ArcGIS OFS Admin Files Create” Oracle Integration Cloud integration flow. It generates a new set of CSV files. Download the files to your machine where ArcGIS Pro is installed.
