About Oracle Integration Cloud
Oracle Integration Cloud is a unified platform to integrate the applications, automate processes, and create applications.
Using integrations connect the applications into a continuous business flow. The integrations can be quickly developed and activated between both the cloud and on-premise applications. The lookups help to match application specific codes between the two applications. Oracle Integration Cloud provides graphical mapper where user can map just by drag and drop between the applications.
