Accelerator Activity Types
This accelerator is used as a starting point for customer implementation. It provides configurations for the following basic Activity Types. Customers should create UIs for additional activity types or customize the existing UIs for the supported Activity Types. Reopened activities are also supported in this integration.
• Install Meter
• Remove Meter
• Read Meter
• Replace Meter
• Install Item
• Replace Item
• Connect SP
• Disconnect SP
