Properties
Properties are customs fields used to enable the Utility Integration specific UIs created, and to map the Oracle Field Service UIs. Each property is classified into types (such as field, integer, enumeration and string) based on the requirements. They should be addressed using this property.
For this integration, the properties to enable utility specific functionally and UIs are created in Oracle Field Service. Property includes meter read, meter, item, and other completion related details.
To import the property file that is a part of the accelerator package:
1. On the Configuration page, select Resources, Activities, Inventories > Properties.
2. Click Import.
3. Browse to the location of the file to be imported and click Import.
4. Verify the successful import of the file. The Successfully Imported message with number of properties imported is displayed. Make sure the Imported with warnings and Not imported count is 0.
5. Click Close.
