Lookup Name | Integration Name | Purpose |
OUTL-BRT-DACS_DRMS_AssetType | OU DERMS DACS Enrollment Request | |
OUTL-BRT-DACS_DRMS_AssetSpec | OU DERMS DACS Enrollment Request | Translate DERMS device make and model (format MAKE!MODEL) to DACS asset specification. |
OUTL-BRT-DACS_DRMS_ConfigProps | • OU DACS DERMS CommonErrorHandler • OU DACS DERMS Device Score FTP Transfer • OU DACS DERMS Device Score OS Transfer • OU DACS DERMS Device Status Check • OU DERMS DACS Device Status Ack • OU DERMS DACS Enrollment Request • OU DACS DERMS Enrollment Sync • OU DERMS DACS Enroll Sync Ack • OU DERMS DACS Event Device Reserve • OU DERMS DACS Event Outcome Process • OU DERMS DACS ProgramEvent Status Update | Generic properties and default values used in the integration’s business logic and mappings |
OUTL-BRT-DACS_DRMS_DeviceLocationStatus | OU DACS DERMS Enrollment Sync | Translate device status values between applications |
OUTL-BRT-DACS_DRMS_Email_ID | • OU DACS DERMS Common Error Handler • OU DACS DERMS Device Score FTP Transfer • OU DACS DERMS Device Score OS Transfer • OU DERMS DACS Event Device Reserve • OU DERMS DACS Event Outcome Process | Provide the email information to send error details: • to property contains the email address(es) of people who handle technical issues like network connection issues, 401 unauthorize issues. • to.ProcessNotification property contains the email address(es) of business or application users in DACS and/or DERMS. |
OUTL-BRT-DACS_DRMS_EventType | • OU DERMS DACS ProgramEvent Status Update | Translate event type between applications |
OUTL-BRT-DACS_DRMS_Routing | • OU DACS DERMS Device Status Check • OU DERMS DACS Event Outcome Process • OU DACS DERMS Enrollment Sync • OU DERMS DACS Event Device Reserve | This lookup is used to route the DERMS environment instances to the DACS CIS Division |
OUTL-BRT-DACS_DRMS_EnrollmentStatus | OU DERMS DACS Enrollment Request | Translate the enrollment status to code |
OUTL-BRT-DACS_DRMS_EventOutcome | OU DERMS DACS Event Outcome Process | Translates the incoming event outcome to DACS code |
OUTL-BRT-DACS_DRMS_StageStatus | OU DERMS DACS ProgramEvent Status Update | Translate stage status values between applications |
Property Name | Sample Value | Description |
notification.type. | email | Hardcoded value for the integrations to send to the 'common error handler' to decide how to send the notifications out. In future release this might be augmented with other types besides the current default: 'email' |
notification.email.error.flag | true | If the value is set to true, email notification will be sent out for errors. Valid values: true/false. Default to true. Also, setup the OUTL-BRT-DACS_DRMS_Email_ID 'to' property for the users or administrators who should receive the email. |
notification.email.pro cess.complete.flag | true | If the value is set to true, email notification will be sent out when the process is completed. Valid values: true/false. Default to true. This is used by flows doing file processing. Also, setup the OUTL-BRTDACS_DRMS_Email_ID 'to.process.notification' property for the users who should receive the email. |
notification.email.pro cess.nofile.flag | true | If the value is set to true, email notification will be sent out when no file was processed. Valid values: true/false. Default to true. This is used by flows doing file processing. Also, setup the OUTL-BRTDACS_DRMS_Email_ID 'to.process.notification' property for the users who should receive the email. |
enrollmentSyncAckDelay | 5 | Value is in seconds. Delay before seeing an enrollment acknowledgement back. |
dacs.enrollmentSource.default | X1BY | Default to X1BY (Bring Your Own). This is used in Enrollment Request flow. Valid Values: • X1BY - Bring Your Ownm • X1CC - Contact Center • X1SS - Self Service |
dacs.prefixtag.fileuploaded | Sent- | Prefix to append to the filename from DACS that has been transferred successfully to the target location. Shared property for all file related flows in this integration. |
dacs.prefixtag.filenot uploaded | Error- | Prefix to append to the filename from DACS to mark the file as error or not uploaded to the target location. Shared property for all file related flows in this integration. |
dacs.dvcScore.extract .filename.prefix | DeviceScore | Device Score Extract file name prefix. It should have the same beginning value as the batch parameter filename in Batch Process X1-SDCSE. Integration use this for filtering the file(s) to pick up from DACS file location by the Device Score flows. |
dacs.dvcScore.ftp.input.directory | /sploutput/DACSEnv/DvcScore | DACS FTP directory where the Device Score extract files are stored for OIC to pick up from. Required to be populated when DACS is on-premises. |
dacs.os.namespace | dacsnamespace | DACS Object Storage namespace serves as a container for all DACS related buckets and objects. It is used when calling the Object Storage APIs. Required to be populated when DACS is in the cloud. |
dacs.os.dvcScore.bucket name | DACS_DVCSCORE | Define the bucket name where the Device Score Extract files are stored in the DACS Object Storage for OIC to pick up from. It is used when calling the Object Storage APIs. Required to be populated when DACS is in the cloud. |
dacs.error.ack.messagecategory | 11114 | DACS - Integration Message Category |
dacs.error.ack.messagenumber | 31002 | Error occurred while processing request to NMS %1%2%3%4%5%6%7%8%9 |
Property Name | Value | Description |
PENDING | SUCCESS | |
ERROR | ERROR | |
VALERROR | ERROR | |
FAILURE | ERROR | |
10589 | SUCCESS | Duplicate errors can be ignored |
From | admin@myCy.com | The email address used to identify who is sending the notification. This value is the default email address for all outgoing emails for this project. |
To | errorDist@myCy.com | The email address(es) who should receive any error notification. Multiple emails can be configured by putting comma to separate the email IDs. These are likely the administrators or users who maintain the applications. |
to.process.notification | busUserDist@myCy.com | The email address(es) who should receive notification when the file processing has completed, or no file was processed. Multiple emails can be configured by putting comma to separate the email IDs. These are likely the business or application users. |
DRMS_EventType | DACS_EventType | Description |
X1EC | X1EC | |
X1EM | X1EM | |
X1DT | X1DT | |
X1RE | X1RE |
DRMS_StageStatus | DACS_StageStatus | Description |
CANCELED | F1CN | |
COMPLETED | F1CO | |
IN_PROGRESS | X1IP | |
SCHEDULED | X1SD |
DRMS_Instance | DRMS_Site_ Connection | DACS_CIS_Division | DACS_Connection |
Attribute Value of DERMS SITE in DRMS Parameters | Name of OIC Connection | CIS Division value | Name of DACS Connection |
DACS_DEVICE_LOC_STATUS | DRMS_DEVICE_ STATUS | Description |
D1YS | Active | Value for DACS/DERMS for active or inactive device |
D1NO | Inactive |
DRMS_ASSET_TYPE | DACS_ASSET_TYPE | Description |
SMART_THERMOSTAT | SMART THERMOSTAT | Value for DACS/DERMS for type of device |
DRMS_MAKE_ MODEL | DACS_ SPECIFICATION | Description |
NEST!N3GEN | EST_G3_SPEC | Value for DACS/DERMS for device |
NEST!N4GEN | ZZ_CTRL_DVC_THERM_SPEC22 | |
ECOBEE!E3GEN | EcoBee_E3 |
