Integration Name | End Point URL to be Configured | Application to be Configured |
OU NMS OCI Stream Notif Upload | https://OIC_instance.REGION.ocp.oraclecloud.com:OIC_Port/ic/api/integration/v2/flows/oracleutilities/project/OUTL-BA-NOTIFICATIONS_HUB/OUTL-BA-NMS_STREAM_NOTIF_UPL/1.0/NMS/Outages | Oracle Utilities Network Management System |
OU CCB OCI Stream Notif Upload | https:// OIC_instance.REGION.ocp.oraclecloud.com OIC_Host:OIC_Port/ic/api/integration/v2/flows/oracleutilities/project/OUTL-BA-NOTIFICATIONS_HUB/OUTL-BA-CCB_STREAM_NOTIF_UPLOAD/1.0/notifications Note: If the base flow is cloned for customization and the customized flow is used, replace OUTL-BA- CCB_STREAM_NOTIF_UPLOAD in the URL with identifier of the cloned flow. | Oracle Utilities Customer Care and Billing |
