Managing Web Service Catalog
The web service catalog is used by Oracle Integration Cloud to communicate with the respective application. It is used to identify the services that should be retrieved by the Oracle Utilities Adapter. It is configured in Catalog URL in the Oracle Integration Cloud connection.
To configure the catalog in Oracle Utilities Customer Cloud Service:
1. Login to Oracle Utilities Customer Cloud Service.
2. Navigate to the Web Service Catalog page either from the Admin > [W or Integration] menu or from the Search menu.
3. Select REST Web Service Class.
4. Add the REST inbound web services mentioned below to the catalog.
Service Type
Service Name
Description
Inbound Web Service
C1-UnsubscribeNotifications
Unsubscribe Notifications
Inbound Web Service
C1-TemplateBasedNotifTypes
Template Based Notification Type
Inbound Web Service
C1-CustomerContactNotification
Create/Update Customer Contact
Inbound Web Service
C1-NotificationPreferencesForAccounts
Notification Preferences for Accounts
5. For outbound messages, add the External System that was set up previously.
For more information about the configuration, refer to the Oracle Utilities Customer Cloud Service documentation.
