Configuration Properties
OUTL-BRT-NOTIFHUB_ConfigProps.dvm contains the properties that can be defaulted in the integration. It also contains a flag to enable email notifications.
Property Name
Sample Value
Description
Used in Integration Process Name
nms.datafield.propertylist
OUTAGETIME,CUSTOMERSOUT,CAUSE, ESTRESTTIME,
CREWETA,
COMPLETIONTIME
Oracle Utilities NMS OCI Stream Notif Upload
email.flag
True
If this value is set to true, an email notification will be sent out.
Valid values: true/false
Default: true
• Oracle Utilities OCI Stream Responsys Notif Send
• Oracle Utilities NMS OCI Stream Notif Upload
• Oracle Utilities OCI Stream Notif linkChannel
• Oracle Utilities OCI Stream Notif Upload
resp.email.permission
OPTOUT
Merges the rule corresponding to “defaultPermissionStatus” field in Oracle Responsys API. Do not change.
resp.reject.channel.empty
E,M
Merges the rule corresponding to “rejectRecordIfChannel
Emtpy”field in Oracle Responsys. Do not change.
resp.optout.value
O
Merges the rule corresponding to “optoutValue” field in Oracle Responsys.
resp.optin.value
I
Merges the rule corresponding to “optinValue”field in Oracle Responsys.
resp.update.on.match
REPLACE_ALL
Merges the rule corresponding to “updateOnMatch” field in Oracle Responsys. Controls how the existing record should be updated.
resp.match.operator
NONE
Merges the rule corresponding to “matchOperator” field in Oracle Responsys. Operator to join the match column names.
Form.base64.encoded
true
Indicates if the Unsubscribe data in the files is base64encoded.
Oracle Utilities Responsys CCB Pref Unsubscribe
max.error.count
30
Maximum count of errors at which to send an email notification.
Oracle Utilities Responsys CCB CCB Contact Create
