Importing the Oracle Integration Cloud Project from Oracle Cloud Marketplace
All integration points are shipped as part of single project (OUTL-BA.NOTIFICATIONS_HUB.1.24.1000.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Browse through the list of applications and select the pre-built integration project to import.
Alternatively, you can search for “Oracle Utilities” and select the Notifications Hub integration option.
4. Click GetApp.
5. Review and accept the “Oracle Standard Terms and Restrictions”.
6. Click Next. The My Oracle Support portal opens.
7. Download the integration package from My Oracle Support.
8. When prompted, select the server where the pre-built integration file should be uploaded.
The pre-built integration is imported as a project file (.car) that is visible on the Projects page in Oracle Integration Cloud.
9. On the Integrations page, the individual integrations of the imported project file that are designated with a BUILT BY ORACLE message are displayed.
To import a project in Oracle Integration Cloud:
1. Login to Oracle Integration Cloud.
2. Navigate to Projects.
3. Click Add and then click Import.
4. Select the .car file downloaded from Oracle Cloud Marketplace. Drag and drop the file to the browser area.
5. Verify if the project is imported is successfully.
