Using the Sample Supplemental Table
The base OU_Campaigns.zip provided has a sample supplemental table “UnsubscribeData” that is used to store unsubscribe data. The sample supplemental table has the required columns needed to produce files which is in turn used by the integration.
Important! The columns needed should be defined with the same name and order as shown below. This is required for the corresponding csv files to be generated with columns in the same order.
ACCOUNT_ID
CONTACT_ID
NOTIF_PREF_ID
CONTACT_VALUE
CONTACT_TYPE
NOTIF_TYPE
UNSUB_PK
