Importing Folders
To import campaigns:
1. Delete the OU_Campaigns folder that was imported as part of Notifications Hub integration (if it exists in the Oracle Responsys instance). Make sure there is no existing folder with the name OU_Campaigns in the Oracle Responsys instance.
2. To import the OU_Campaigns.zip sample campaigns file, click Import in the Folder section of Oracle Responsys.
3. Make sure that the import was successful. Check if the OU_Campaigns folder was created. OU_Campaigns folder has sample email campaigns, sample form and sample supplemental table used in “Unsubscribe” functionality.
