Configuration Properties
The ERPWACS_ConfigProps lookup includes properties that can be defaulted in the integration. It also contains a flag to enable email notifications.
Property Name
Sample Value
Description
email.flag
true
Flag to indicate to send out email notifications
maxerrorcount.per. emailnotification
50
An email notification is sent after the maximum number of records in error set here is reached. It will keep sending an email notification for every interval of the maximum error count.
Example: There are 150 records to be processed and this property is set to 50. When the process reached it's 50th error record then an email notification listing the 50 error records is sent. For every 50 error records an email notification is sent.
wacs.externalsystem
GD_INT_ERP
This value is obtained in WACS. This must be a valid expense code in WACS.
wacs.usageexpensecode.
default
DK_USG_EXP
erp.purchase.itemcategory
Purchasing
This is the Purchase item Category defined in ERP. This is used to get the category name to be mapped to WACS Purchase Commodity field.
erp.assetactivity.useritem
typevalue
Asset Activity
This is the Asset activity User Item Type defined in ERP. This is used in the WACS repairable mapping.
execute.stockitem.bulk
yes/no
Flag to continue the execution of the flow Oracle Utilities ERPPIM WACS Item Initial Sync
invoke.sid.inc.sync
yes/no
Flag to invoke the child Integration OU ERPSCM WACS Stock Item Detail Incremental Sync to create/update the Stock Item Details for the created/updated Stock Item.
