Email Notifications
This pre-built integration includes a configurable email notification.
To receive an email notification:
1. Login to Oracle Integration Cloud.
2. Navigate to Projects > OU WACS ERPSCM > Lookups.
3. Edit the ERPWACS_ConfigProps lookup.
Change the email.flag property value to ‘true’.
4. Edit the ERPWACS_Email_ID lookup.
a. In the from field, enter the email ID to receive an email from.
b. In the to field, enter the email ID to send the email to.
Use a comma to separate the email IDs when multiple email IDs are defined.
Note: In the ERPWACS_Email_ID lookup, do not edit the values provided under the Recipient column.
