Integration Overview
Oracle Utilities Work and Asset Cloud Service Integration to Oracle ERP Product Hub Cloud synchronizes stock items from Oracle ERP Product Hub Cloud to Oracle Utilities Work and Asset Management for new and updated items.
The following diagram provides a high-level representation of the integration: Illustrates the business processes supported in this integration product.
The advantages of this integration are:
• Enables maintaining information pertaining to a Items in Oracle ERP Product Hub Cloud as central repository and Master for both systems.
• Smart View report or Oracle Transactional Business Intelligence Analyses can be done for Item process in Oracle ERP Product Hub Cloud.
• Audit Capability in both system is available.
• Seamless integration between two products.
• Easy and quick deployment.
• Reduces IT and administrative costs.
The mapping of fields attributes for some fields are direct and for some DVM are required for records creation in Oracle Utilities Work and Asset Cloud Service.
The integration will support Bulk upload and incremental updates to Oracle Utilities Work and Asset Cloud Service.
• BULK /INITIAL Upload
• Incremental Upload
Starting release 24A, the bulk and incremental updates of this integration have dependency on the Oracle Utilities Work and Asset Cloud Service Integration to Oracle Supply Chain Management. The following actions are required during implementation of the integration.
BULK/INITIAL Update
When the customer is executing the bulk/initial item synchronization, the execute.stockitem.bulk property in ERPWACS_ConfigProps within Oracle Integration Cloud has to be set to ‘yes’. After the bulk/initial item synchronization is completed, set the property to ‘no’.
If Oracle Utilities Work and Asset Cloud Service Integration to Oracle Supply Chain Management is implemented, ensure the “execute.sid.bulk” property in ERPWACS_ConfigProps within Oracle Integration Cloud is set to ‘no’ during the execution of bulk/initial item synchronization of the Oracle ERP Product Hub Cloud Integration to Oracle Utilities Work and Asset Cloud Service.
Incremental Update
If the customer is implementing Oracle Utilities Work and Asset Cloud Service Integration to Oracle Supply Chain Management, set the invoke.sid.inc.sync property in ERPWACS_ConfigProps within Oracle Integration Cloud to ‘yes’. If not, the property should be set to ‘no’.
For more information about the integration, refer to the Oracle ERP Product Hub Cloud Integration to Oracle Utilities Work and Asset Cloud Service for Stock Item Configuration Guide included in this release.
