The following table lists the application versions required for this integration:
Application
Version
Oracle Utilities Work and Asset Cloud Service
24A or higher
Oracle Integration Cloud
V24.02 or higher
Oracle ERP Product Hub Cloud
24A or higher
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
