Introduction
This integration provides the ability for a customer to manage all the item information and details in one primary instance (Oracle ERP Product Hub) and communicate with Oracle Utilities Work and Asset Cloud Service:
Oracle ERP Product Hub will be the master for all Item information.
This seamless integration between Oracle ERP Product Hub and Oracle Utilities Work and Asset Cloud Service helps to have the same Item definition across both platforms.
The integration will support Bulk upload and incremental updates to Oracle Utilities Work and Asset Cloud Service.
Bulk Upload: Oracle ERP Product Hub to Oracle Utilities Work and Asset Cloud Service
Incremental Update: Oracle ERP Product Hub to Oracle Utilities Work and Asset Cloud Service
The goals for Oracle ERP Product Hub to Oracle Utilities Work and Asset Cloud Service one-directional interface are to make sure that there is a seamless integration between Oracle ERP Product Hub and Oracle Utilities Work and Asset Cloud Service:
To make sure the items are synchronized.
To make sure Oracle ERP Product Hub is the source of record for Items and Item attributes.
To make sure Oracle Utilities Work and Asset Cloud Service is always a mirror image of Oracle ERP Product Hub.
To document all required columns to be mapped between Oracle ERP Product Hub and Oracle Utilities Work and Asset Cloud Service.
