Known Issues
The known issues at the time of this integration release are:
• Even after the supervisor locks an activity, assistant mobile worker is able to perform the asset level operations.
• Undo use item is getting displayed in day2 when the item is used for day1 in multiday activity.
• Error message is not displayed in the Oracle Field Service mobile screen when the crew member starts the successor activity before the predecessor activity.
• In the Oracle Field Service mobile screen, when the crew navigates to the Activity Dependencies tab, the same activity is displayed on the Successor and Predecessor tab.
• Admin Sync known issue:
• The enumeration “wam_actType_psh” to maintain the relationship between the activity types and PSH associated with the activity types. It stores the PSH details as part of the name for the enumeration label. In Oracle Field Service, there is a restriction on the size of the name. If there are more than 5-6 PSHs for that activity type, Oracle Field Service displays a 500 error.
• Activity creation will fail in Oracle Integration Cloud if craft and equipment from Oracle Utilities Work and Asset Cloud Service have special characters.
• Refresh activity operation or Resend from Oracle Utilities Work and Asset Cloud Service is not updating the Asset Attributes for existing pool inventories if there is any change in asset attributes in Oracle Utilities Work and Asset Cloud Service.
