Property Name | Sample Value | Description |
wacs.externalsystem | ERP | Fixed value “ERP” |
wacs.storeroom. category | W1ST | Storeroom Category fixed value “W1ST” |
wacs.storeroom.active. code | W1AC | Storeroom Active Code fixed value “W1AC” |
notification.email.process.complete.flag | true | Set to “true” to send notification after integration is processed. Else, set to “false”. |
notification.email.process.nofile.flag | true | Set to “true” to send when no file is found. Else, set to “false”. |
fileprocessed.prefixtag | Sent- | File prefix needs to be updated to Sent-/-/Processed- when it is processed scussessfully without errors. |
filenotprocessed. prefixtag | Error- | File prefix needs to be updated to Error- when it is processed with errors. |
item.assign.stockitemdetail.class | W1IN | Stock item details class fixed value “W1IN” |
execute.sid.bulk | yes | Set to “yes” to run SID sync in bulk. |
wacs.storeroom. batchtype | increment | Property used to identify bulk or increment storeroom sync to call SID sync process. |
item.adjust.bipreport | /Custom/SCMWACS/Inv Adj/ERPSCM_InvAdjReport_WACS.xdo | Path of the BI Report Object. |
notification.type.email | email | Notification type |
notification.error.flag | true | Flag used in error handler to send an email notification. |
wacs.sid.active.code | ACTIVE | Active storerom SID Sync fixed value “ACTIVE” |
wacs.sid.inactive.code | INACTIVE | Inactive storerom SID Sync fixed value “INACTIVE” |
wacs.storeroom.inactive.code | W1IA | Inactive Storeroom code fixed value “W1IA” |
wacs.sid.create.code | CREATED | SID Create Code fixed value “CREATED” |
erp.subinventory.type | Storage | SubInvType fixed value “Storage” |
