Importing the Oracle Integration Cloud Project from Oracle Cloud Marketplace
All integration points are shipped as part of single project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
2. Click Applications.
3. Search for “Oracle Utilities Work and Asset Cloud Service”.
4. Browse through the list of applications and select the pre-built integration project to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. My Oracle Support portal opens.
8. Download the integration project from My Oracle Support.
9. When prompted, select the server where the pre-built integration file should be uploaded.
The pre-built integration is imported as a project file that is visible on the Projects page in Oracle Integration Cloud.
10. On the Integrations page, the individual integrations of the imported project file that are designated with a BUILT BY ORACLE message are displayed.
Important! This note is applicable only for existing customers. Make sure to take a backup of the existing project and lookups, and perform the cleanup before proceeding with the new project import. The cleanup includes deactivating the existing flows in this project and deleting the project, connections, lookups and libraries used in the integration.
To import a project in Oracle Integration Cloud:
1. Login to Oracle Integration Cloud.
2. Navigate to Integrations > Designer > Projects.
3. Click Import.
4. Select the .car file downloaded from Oracle Cloud Marketplace.
5. Verify if the OU WACS ERPSCM project is imported successfully.
