Creating Item in ERP
To create an inventory item in ERP:
1. Login to Oracle Fusion ERP Cloud.
2. Navigate to Product Management > Product Information Management.
3. From the Tasks menu, click Create Item.
4. In the Create Item pop-up screen:
a. Select the Organization.
b. Mention the number of items to create.
c. Select the Item Class.
d. Select the Template.
e. Click OK.
5. On the Create Item page:
a. Enter the Item Number.
b. Add the Description.
c. Select the Item Status.
Note: Only items with Active status will be synchronized to Oracle Utilities Work and Asset Cloud Service as part of the Item Creation request.
d. Select Life Cycle Phase, User Item Type, and Pack Type.
e. On the Overview tab, select the primary Unit of Measure.
f. On the Specifications tab, under Item Organization, do the following:
a. On the Service tab, select Asset > Enable Asset Tracking value.
Note: Only “Not Tracked” assets are supported in this release.
b. On the Inventory tab, select Lot > Control value.
Note: Only “No Lot Control” items are supported in this release.
c. On the Purchasing tab, select Unit of Issue value.
d. On the Categories tab, add WACS category and WACS catalog.
g. Click Save.
This will trigger Item Create Event, which in turn will trigger the integration flow that is subscribed to the Item Create Event.
