Creating Sub Inventory in ERP
To create a sub inventory in Oracle Fusion ERP Cloud:
1. Login to Oracle Fusion ERP Cloud.
2. Navigate to Other > Setup and Maintenance.
3. From Setup and Maintenance, select the Manufacturing and Supply Chain feature.
4. Click Inventory Management > Manage Subinventories and Locators.
5. Select Organization and click OK.
6. In the Search Result region, click Create Icon.
7. Add the following details in the Create Subinventory Summary section:
• Subinventory, Description, End Date
• Material Status: Active
• Subinventory Type: Storage/Regular
8. Add the following details in the Location section:
• Locator Structure: Four-Segment Locator Structure Instance
• Asset Subinventory: Yes
• Click Save and Close.
9. Navigate to Offerings > Create Offering.
• Enter the BICC batch job parameters and run the job.
• Job Name: ERPINV_WACS_SUBINVENTORY_BULK/INCR
• Job Name: ERPINV_SUBINV_BULK/INCR
• Job Type: Application Data Extract
• External: UCM
• Storage Recurrence: Immediate
• Notification: Use Global Extract Schedule Notification
• Use Global File parameters: Yes
• Compression type: Zip
