Managing Catalog Services
The catalog service is used by Oracle Integration Cloud to communicate with the respective application. It is configured in the Catalog URL field in the Oracle Integration Cloud connection page of Adapters.
To configure the Catalog Service for this integration process:
1. Login to Oracle Utilities Work and Asset Cloud Service.
2. Navigate to the Web Service Catalog page either from the Admin menu or the Search menu.
The inbound web services mentioned in the table in step 3 are added to the catalog.
3. To get the catalog URL, append “webservices/builtin/ServiceCatalog?wsdl” to the on-premises application.
Example: http(s)://<WAM_HOST>:<WAM_PORT>/<ContextRoot>/webservices/builtin/ServiceCatalog?wsdl
If you are using Oracle Utilities Work and Asset Cloud Service, the format should be: https://{host}:{port}/{tenant}/{domain}/{appName}/soap/api/iws/ ServiceCatalog?WSDL
Following is the list of artifacts to be included in web service catalog:
Note: Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service is a prerequisite for this integration. For information about configurations, refer to the Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service Configuration Guide at: https://docs.oracle.com/en/industries/energy-water/integrations-index.html
For more information about Oracle Utilities Work and Asset Cloud Service configurations, refer to the Oracle Utilities Work and Asset Cloud Service documentation available on Oracle Help Center at:
https://docs.oracle.com/en/industries/energy-water/work-asset-cloud-service/index.html
