Configuring Lookups
The following table lists the lookups that are part of this integration.
Lookup Name
Integration Name
Purpose
OUTL-BRT-ArcGIS_OFS_ConfigProps
• OU ArcGIS OFS Work Task Process
• OU ArcGIS OFS Admin Files Create
• OU OFS ArcGIS Activities Delete
• OU OFS ArcGIS Activities Sync flow
Used for configurable properties.
OUTL-BRT-ArcGIS_OFS_Email_ID
Used to configure email IDs of the respective users.
Under the Email_Id column where the value of Recipient is “to”, add comma separated email IDs to send an email to multiple users.
Do not change or add any values under the Recipient column.
OUTL-BRT-ArcGIS_OFS_ActivityType
OUTL-BRT-ArcGIS_OFS_AssetSearchField
OU OFS ArcGIS Activities Sync Flow
Used to get search value that can be configured as part of Field maps URL link in a Arcade expression to search for an asset:
• Asset Type: WACS asset type for a given asset. Example: WD-PoleWood
Note: Each WACS asset type must correspond to a unique feature layer ID, so that the asset can be linked and searched in that particular feature layer.
• FeatureLayerID: ID of the corresponding asset in ArcGIS.
• SearchField_1: A configured search field for this layer in ArcGIS Webmap/Field Map.
• SearchField_2: A configured search field for this layer in ArcGIS Webmap/Field Map. This field will be looked at if the SearchField_1 attribute returns empty or null.
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Projects.
3. Select the project and then navigate to the Lookups section of the project.
4. Select the lookup to edit.
5. Make the necessary changes.
6. Click Save and Close.
