Configuration Properties
The OUTL-BRT-ArcGIS_OFS_ConfigProps lookup contains the properties that can be defaulted in the integration. It also contains a flag to enable email notifications.
Property Name
Sample Value
Description
Used in Integration Process Name
source.system
WACS
Defines the WAM or WACS product code
OU ArcGIS OFS Admin Files Create
notification.email.error.
flag
true
If the value is set to ‘true’, email notification will be sent out for errors.
Valid values: true/false
Default: true
Also, setup the OUTL-BRT-ArcGIS_OFS_Email_ID 'to' property for the users or administrators who should receive the email.
ofs.activities.buckets
OHMeter
The property is used to configure the OFS buckets where the activities are assigned.
OU OFS ArcGIS Activities Sync flow
wacs.projectedcoordinatesystem.wkid
4326
This property is used to configure the coordinates system [wkid] which will be used to retrieve the geometry coordinates in the specified system format.
arcgis.asset.search
false
This property is used to enable or disable the asset search logic in the flow if the navigating to an asset based on search value feature is not used in the popup.
Refer to the Oracle Field Service and ESRI ArcGIS Field Maps Configurations for ESRI ArcGIS Field Maps Integration to Oracle Field Service Mobile Setup Guide included in this release for more information on configuring links in the popup based on search value.
The asset search property is used in the flow to get the value of search field element of the asset configured in the lookup.
notification.email.invalidactivities.flag
False
If the value is set to 'true', email notification with invalid activities that have not been synchronized to ArcGIS will be sent out.
As an example, the activities which has invalid longitude and latitude will not be synchronized and that activity information will be sent through the email if this flag is configured to true.
activity.status.include
cancelled,started,completed,pending,suspended,enroute,notdone
The property is used to determine the status of the OFS activities that needs to be considered for add/update in Activites feature class.
This list can be modified to remove the status so that activities belonging to that status will not be synchronized.
notification.email.process.complete.flag
true
Configures the optional email notification. If the value is set to ‘true’, email notification will be sent to the configured users.
Also, setup the OUTL-BRT-ArcGIS_OFS_Email_ID 'to.process.notification' property for the users or administrators who should receive the email.
asset.inventory.type
Asset
OU ArcGIS OFS Work Task Process
ofs.default.bucket
OHMeter
Configure the default bucket to assign the activities.
notification.email.deleteactivities.flag
False
Sends a notification email when the delete process finishes. By default, flag is set to false.
OU OFS ArcGIS Activities Delete
The OUTL-BRT-ArcGIS_OFS_Email_ID lookup contains the properties that can be defaulted in the integration. It also contains a flag to enable email notifications.
Property Name
Sample Value
Description
from
arcgis-ofs@email.com
to
errorDist@myCy.com
The email address(es) who should receive any error notification. Multiple emails can be configured by putting comma to separate the email IDs.
These are likely the administrators or users who maintain the applications.
• OU OFS ArcGIS Activities Delete
• OU OFS ArcGIS Activities Sync
busUserDist@myCy.com
The email address(es) who should receive notification when the processing has completed. Multiple emails can be configured by putting comma to separate the email IDs.
These are likely the business or application users.
• OU ArcGIS OFS Admin Files Create
