Bug/Reference Number | Description |
37069526 | Failed OIC instance ID is not appended to email notification when failure occurs at asset search in the Activities Sync flow. |
37049460 | Description for cancelled activities in the Activities Delete flow in OIC and in email content should in line with the logic. |
37036703 | Activities Sync flow failed to send email notification in case of business fault. |
36972889 | Work Task flow receives a positive acknowledgement in cases when CREATEWORKREQUEST fails. |
36972603 | Warning message when navigating from Field Maps in offline mode to create workorder/work request in OFS. |
