Enabling Offline Capability
To work in the disconnected mode, webmaps can be configured offline in Fieldmaps. To take webmaps offline, all the layers of the webmaps must be enabled for offline use.
To enable offline feature layer on the portal for ArcGIS Enterprise Server, refer to:
https://enterprise.arcgis.com/en/portal/10.9.1/use/take-maps-offline.htm
