Required Software
The following software is required to configure and deploy the Tasks feature layer:
• ArcGIS Pro (3.2 or higher): A desktop client used to create database connection, server connection, load the domain and contingent values, and publish the Task layers to the server.
For information on getting started with ArcGIS Online, see: https://doc.arcgis.com/en/arcgis-online/get-started/create-account.htm
• ArcGIS Online or ArcGIS Enterprise Server: To publish the Tasks feature layer.
Note that if you are using Oracle database, the minimum version of Geodatabase supported is 10.9.1.
