Supported Applications
The following table lists the supported application versions in this integration:
Product Name
Version
Oracle Utilities Customer Care and Billing
V2.8.0.0.0 or higher
Oracle Integration Cloud
V24.06.0.0.0 or higher
Oracle Field Service
24B or higher
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
