Importing the Oracle Integration Cloud Project from Oracle Cloud Marketplace
All integration points are shipped as part of single project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Oracle Utilities Customer Cloud Service”.
4. Browse through the list of applications and select the pre-built integration project to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. MyOracle Support portal opens.
8. From the integration artifacts table, click the link to download the CCS-OFS Business Accelerator Project (.car) file from MyOracle Support.
• OUTL-BA-CCS_OFSC-01.24.2000
9. Perform the following steps before importing the new Accelerator Project (.car) file into your Oracle Integration Cloud instance.
a. Take a backup of the existing customized integrations and lookups.
b. Perform cleanup by deactivating and deleting the existing flows, connections, lookups, libraries used in the integration and the .par package file.
Note: If your previous pre-built integration was package based (.par file), note the following:
• The package is visible on the Design-Packages page in your Oracle Integration Cloud instance.
• The individual integration flows are visible on the Design-Integrations page. Each integration flow is designated with an Accelerator and BUILT BY ORACLE message.
To import a project in Oracle Integration Cloud:
1. Login to Oracle Integration Cloud.
2. Navigate to Integrations > Projects.
3. Click Add.
4. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
The new project will show up in the list “Configured” status since the connections are not completed yet.
5. Click Project Edit and follow the verification and configuration steps documented in the respective sections.
6. If all configurations are complete, activate the integration by:
• Clicking Activate in the Design page.
• Or, activate the latest deployment plan in the Deploy page.
7. Verify if the OU CCS OFSC project is imported is successfully.
