Importing the Oracle Accelerator Project from Oracle Cloud Marketplace
All integration points are shipped as part of a single accelerator project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Utilities Digital Asset Cloud Svc. to Distributed Energy Resource Mgmt. System”.
4. In Filter by Region/Country, select the North America checkbox.
5. Select the pre-built integration project.
6. Click GetApp.
7. Review and accept “Oracle Standard Terms and Restrictions”.
8. Click Next. My Oracle Support portal opens.
9. From the integration artifacts table, click the link to download the DACS-DERMS Business Accelerator Project (.car) file: OUTL-BA-DACS_DERMS-01.24.2000.car.
10. Perform the following steps before importing the new Accelerator Project (.car) file into your Oracle Integration Cloud instance.
a. Take a backup of the existing customized integrations and lookups.
b. Perform cleanup by deactivating and deleting the existing flows, connections, lookups, libraries used in the integration and the (.par) project file.
Note: If your previous pre-built integration was package based (.par file), you will see the following:
• The package is visible on the Design-Packages page in your Oracle Integration Cloud instance.
• The individual integration flows are visible on the Design-Integrations page. Each integration flow is designated with an Accelerator and BUILT BY ORACLE message displayed.
11. In the Navigation pane, click Projects.
12. Click Add.
13. Select Import Project, then drag-and-drop the (.car) file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
14. The new project will show up in the list but with a status of Configured due to the connections not being completed yet.
15. Click Project Edit and follow the verification and configuration steps documented in the following sections.
16. If all configurations are complete, activate the integration by:
• Clicking Activate in the Design page.
• Or activate the latest deployment plan in the Deploy page.
