About Oracle Integration Cloud (OIC)
Oracle Integration Cloud is a unified platform to integrate the applications, automate processes and create applications.
Using integrations, connect the applications into a continuous business flow. The integrations can be quickly developed and activated between both the cloud and on- premises applications. The lookups help to match application-specific codes between the two applications. Oracle Integration Cloud provides graphical mapper where the user can map just by dragging and dropping between the applications.
