Importing the Oracle Integration Cloud Project Based Accelerator Package from Oracle Cloud Marketplace
All integration artifacts are shipped into a single package (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Oracle Utilities Work and Asset Cloud Service”.
4. Browse through the list of applications and select the pre-built integration package to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. My Oracle Support portal opens.
8. From the integration artifacts table, download the Integration OIC Accelerator Project (.car) file.
OUTL-BA-HCM_WACS-01.24.2001.car
9. Perform the following steps before importing the new project-based accelerator package (.car) into your Oracle Integration Cloud instance:
a. Take a backup of the existing customized integrations and lookups.
b. Perform cleanup by deactivating and deleting the existing flows, connections, lookups, libraries used in the integration and the .par package file.
If your previous pre-built integration was package based (.par file):
It is visible on the Design-Packages page in your Oracle Integration Cloud instance.
On the Design-Integrations page, the individual integrations of the imported package file are designated with an accelerator and BUILT BY ORACLE message is displayed.
10. In the Navigation pane, click Projects.
11. Click Add.
12. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
13. The new project will show up in the list but with the “Configured” status due to the connections not being completed yet.
14. Click Project Edit and follow the verification and configuration steps mentioned in the sections.
15. If all configuration is complete, click Activate in the Design UI. You can also activate the latest deployment plan using the Deploy screen.
