Supported Applications
This table lists the supported applications and their versions in this integration:
Application Name
Version
Oracle Utilities Work and Asset Cloud Service
22A or higher
Oracle Integration Cloud
v20.4.2.0.0 or higher
Oracle Human Capital Management Cloud
20D or higher
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
