Attribute | Value |
OIC_EVENT_OUTCOME_OUAI_URL | https:// hostname:port/ic/api/integration/v2/flows/oracleutilities/project/OUTL-BA-OUAI_DACS_DERMS/OUTL-BA-DRMS_OUAI_EVT_OUTC_TRNFR/1.0/eventOutcome |
OIC_USER | Define OIC Username |
OIC_PASS | Define OIC Password |
MAX_RETRIES | This should be already configured from the implemented DACS-DERMS integration. Value to be set to the amount of retries DERMS will perform upon receiving a technical fault or negative acknowledgment. Note: The drms_outbound_messages database table holds the outbound messages to be resent when the status = 'FAIL' and the num_retries is less than the configured MAX_RETRIES value. If you want to resend a failed message that has already retried the maximum number of times, update the num_retries record back to 0. If you need to resend a successful message for any reason, also update the status to 'FAIL'. |
